Old 2-Aug-2012, 10:19 PM   #4
she.1983
Need multidirectional antenna with UHF and VHF
THanks for reply. But the issue with both the models is they are unidirectional hence I would not be able to get signal from other station at 18/21 or 288 degrees. the issue with rotor is each time when you ant to see that channel you need to rotate the antenna, problem is at our home they don't know how to do that and it is hassle
she.1983 is offline   Reply With Quote
