Tv Reception.
----> If you must have <---- the Tv stations/channels in the Red reception zone , in all other directions.
Please note the Tv stations/channels are Much Weaker of Signal Strength and have Co-Channel and Adjacent Channel interference issues.
For reception install a Winegard HD7084P antenna on a Channel Master CM9521A antenna rotor to rotate the antenna aim to other directions around the compass to receive the weaker Tv transmissions.
Also install a CM3410 distribution amplifier.
This HD7084P setup , Will Not be connected to the HD7000R antenna setup on to the same coax.
The 2 antenna systems Will be Separate antenna systems.
Please note that a Tv antenna on a antenna rotator is not channel surfing friendly , must wait for antenna to rotate.
