Old 2-Aug-2012, 9:13 PM   #2
Tv Reception.
A simple reception situation.
---->> Many , many , many , many , Tv stations/channels will be received. <<----
For reception of Digital Tv Channels in the Green and Yellow reception zones of the tvfool radar map channel list.
Install a Winegard HD7000R antenna Above the roof aimed at about 70 degree magnetic compass.
Here are some above the roof antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Here are some places to buy antennas and etc. , http://www.solidsignal.com ,http://www.winegarddirect.com , http://www.amazon.com , http://www.channelmasterstore.com.
For 1 Tv connected use No splitter No amplifier.
For 2 Tv's connected use a simple common 2 way splitter , No amplifier.
For 3 or 4 Tv's connected use a Channel Master CM3414 distribution amplifier.
The Tv/s Must Channel Scan for the Broadcast Tv Channels sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
