Old 20-Sep-2010, 10:26 PM   #16
Tower Guy
Originally Posted by goosemasterkl View Post
I ordered a HLSJ to put on my system; in what order does it install at? before this; after that, etc. Also; what antenna do you reccommend? Thanks
The L input of the HLSJ is connected to nothing or a 75 ohm termination.
The H input of the HLSJ is connected to the stacker antenna that you have. The output of the HLSJ is connected to the input of your AP-8700 preamp.
With an HLSJ there should be no need to change antennas. I mentioned other choices so that anyone in a similar situation as yours would get an antenna that doesn't pick up FM.
To eliminate overload from your strongest UHF TV station you may still need to replace the AP-8700 with a HDP-269.
