Wpmt fox 43.1 antenna reception
Someone please help me solve this mystery. How can it be that I am able to receive WGAL (8) with a signal strength of 92 percent at the exact compass heading suggested with a fantastic picture and receive no picture or an occasional "blip" of a picture for a second or two at best with a signal strength of 25 at best intermittently for WPMT Fox 43.1 at it's suggested compass heading? The transmitters are only two degrees apart via compass headings and are basically the same distance from me in miles and WPMT if I read the tranmitter power correctly has a stronger signal than WGAL. I am using the StealthAntenna from Channelmaster complete with amplifier and properly synchronized rotor. The antenna's height is approximately 30 feet from the ground. I have even changed the antenna direction several degrees in either direction without any change in WPMT 43.1's perfomance of signal strength or picture. I have zero issues with all the other stations that I should be able to receive for my given location. Thank you in advance for the help.
mike
Reason: additional info
