Old 2-Aug-2012, 5:07 AM   #11
kyaman
Originally Posted by teleview View Post
Is the HD7082P antenna installed??
Is the antenna aimed at about 103 degree magnetic compass??
Adjust the aim of the antenna for better reception of WNBC NBC.
Is the HD7082P in the attic or above the roof??
If the HD7082P antenna is in the attic is the HD7082P close to the other antenna??
Is the HD7082P connected to the other antenna??
Is the HD7082P antenna being used as a FM antenna also??
How many Tv's are connected??
They are both in attic and separate.
Only one is connected to one TV directly with no splits.
So far I find that the VHF antenna is overall better though for some weak channels the UHF does better...
I pointed the winegard to 103 magnetic degrees whereas the old antenna is quite a bit off from that.
The antenna are separated by about 15 feet.
Interesting...
kyaman is offline   Reply With Quote
