Old 1-Aug-2012, 6:47 PM   #3
Tv Reception.
The Tv transmissions are -->Very Strong <-- at your location and are LOS = Line Of Sight.
Install a ANT751 above the roof aimed at about 80 degree magnetic compass reading.
80 degrees is a in between aim direction for reception of the Tv stations to the , north east , east , south east.
As always , the starting antenna aim direction is the --> starting antenna aim direction.
The antenna is then turned to the left and right to see if there is a direction that has better reception of the channels that are to be received , for your reception situation , that is 30 degrees to 140 degrees magnetic compass.
I suspect that about 80 degrees magnetic compass reading will be good.
Here are some above the roof antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560./html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com.
The Tv/s Must Channel Scan for the Broadcast Tv Channels sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
For 3 Tv's connected use a common simple 3 way splitter.
As always antenna reception mileage numbers are a -->General<-- guide for the general public.
I make antenna recommendations of the received signal strength. The signal strengths at your location are Very Strong.
As always , trees and tree leaves that are close in the direction of reception reduce or block Tv reception.
Buildings that are close in the direction of reception reduce and block reception.
Other obstructions that are close in the direction of reception reduce and block reception.
It is best install/mount a antenna where there is the least amount obstructions.
