Old 20-Sep-2010, 6:33 PM   #1
sony1998
Need help selecting an OTA antenna
Thank you for taking the time to help out noobs like me and provide us with your knowledge and experience. This site is truly a valuable service.
Below is my TVFOOL report:
http://www.tvfool.com/?option=com_wr...a362a6e99accf9
I am located in zip code 20874 about 20 miles north of DC
I will be connecting to one analog TV
I live in an apartment complex roof is plywood with shingles, but I have a large balcony on which I can place an antenna tucked up in the ceiling and oriented toward about 150+ degrees. Same type of wood roof. I can not put up a mast there with a rotor either.The balcony is not that big, maybe 8 feet by 5 feet. It is located directly in front of my living area about 10 feet from where the tv is with two large windows looking out over it and the complex.
I am also not opposed to hanging an antenna inside the living room as I have a 10 foot high ceiling.
I am on the 3rd/top floor with no buildings in front of me. However 150 degrees compass reading is pointing parallel to the complex/slightly inward, not out and away into the open. So I do not have a clear shot at the transmission towers.
Over the past week a friend of mine gave me an APEX D to A converter box and I got a non amplified PHILIPS antenna (SDV5119/27) from Walmart to start to experiment with OTA reception. I can always return the antenna and the DtoA box was a freebie. To my surprise I was able to pull in several channels from the FOOL report with just the Philips antenna. My signal reads 30-50 on the meter from the Apex box. There are several channels that fluctuate greatly and can not be locked in.
I know I need a UHF/VHF antenna since ABC is VHF. Some of the BALT. channels have been nice to have as well. If I can pick them up with the Philips antenna I am hoping I can do the same with a larger antenna. However maybe I am wrong because the larger antennas are more directional.
I understand anything I do will be a compromise but I am done with paying the outrageous Ccast bill.
After reading several posts here and other sites I know I can do better with some additional advise from you folks.
I do know that I would like to get a better converter box ( the Channel Master CM-7000) to help my cause in getting better/ reliable reception.
I have also read good things about Winegard antenna but I am not tied to anything and would not know which ones will work in my situation or not and I feel that is the key. An antenna that will work for me. Doesn't have to be pretty, just gets clear and reliable reception without a lot of adjusting.
There you have it. If I can provide any other info please ask.
Now I need your help with antenna possibilities or other equipment necessary for my situation. (antenna, amp, preamp, cable RG6 etc).
Thanks Mark
sony1998 is offline   Reply With Quote
