Old 1-Aug-2012, 4:56 PM   #5
Tv Reception.
Yes I think the ANT751 will work , that is why I recommend it.
The ANT751 does have some forward gain , that is why I recommend aim the ANT751 at the weak Tv station WFXS FOX at 126 degree magnetic compass.
Your location has Tv stations in more then one direction , the ANT751 is not a very directional antenna and receives fairly well in all directions.
Hense , the recommendation of the ANT751 with a CM7778 preamp.
For one Tv connection use no splitter.
For 2 Tv's connected use a ,
HFS-2D , 2 way splitter.
For 3 Tv's connected use a ,
HFS-3D , 3 way splitter.
The HFS splitters pass power through the splitter from the Power supply/Power Inserter on the inside of the house to the actual preamplifier that is mounted close to the antenna.
http://www.hollandelectronics.com , also available at , http://www.solidsignal.com.
