Thanks for the responses. At this point just one TV will be connected. I will probably still get a preamp, though, as the coax run may be fairly long after that point. I should be able to get the preamp very close to the antenna, though. Do you think the ANT751 would work in my situation? It would certainly be easier than mounting two antennas, but I can't find the information about the gain figures and beam pattern to really know if it would have enough gain for my situation or not. Thanks.
