Old 1-Aug-2012, 1:53 PM   #7
Billiam
Originally Posted by signals unlimited View Post
A pre-amplifier will overload due to the strong signals at 283 degrees. The single HD7096 antenna is strong enough to receive the weaker stations including the VHF. Aiming the un-amplified antenna to these weaker stations will produce good reception of the stronger stations at 283. If there are any trees or partial blockages in the direction of the stations, use the slightly larger HD7098P antenna.
According to that report most of his signals are at 270 degrees. And every signal is either Yellow or Red. Nothing is remotely close to being a strong signal at his location.
He needs a preamp. Antenna model HD 7096 or HD 7098 don't exist.
Last edited by GroundUrMast; 1-Aug-2012 at 6:47 PM. Reason: Deleting off-topic comments
