Old 1-Aug-2012, 9:54 AM   #6
signals unlimited
A pre-amplifier will overload due to the strong signals at 283 degrees. The single HD7096 antenna is strong enough to receive the weaker stations including the VHF. Aiming the un-amplified antenna to these weaker stations will produce good reception of the stronger stations at 283. If there are any trees or partial blockages in the direction of the stations, use the slightly larger HD7098P antenna.
