Tv Reception.
The transformers are actually named the transmitters and transmitting antennas.
The preamp is to increase the signal strength at the Tv end of the coax.
And in addition to the preamp , making some antenna adjustments if required , is to receive the 2 Tv channels.
RG-6 quad shied has 4 layers of shield , foil , braid , foil , braid.
Inside the connectors on the ends of the coax , look and see if the foil and braid is pushed in toward the center wire that carries the signal.
if so , push the foil and braid away from the center wire that carries the signal.
