Old 1-Aug-2012, 1:39 AM   #3
Tv Reception.
Those are Very Weak Tv transmissions at your location.
This requires a 2 antenna set up and a preamplifier.
Above The Roof mount a Antenna Direct DB4e UHF antenna aimed at about 265 degree magnetic compass.
And a Winegard YA1713 VHF antenna aimed at about 235 degree magnetic compass.
On the same mast pipe separate the the antennas by about 3 feet , the YA1713 on the bottom the DB4e on top.
Connect the 2 antennas to gather with a UVSJ = UHF/VHF Separator/Joiner also known as a Antenna Combiner.
The UHF antenna is connected to the UHF connection and the VHF antenna is connected to the VHF connection of the UVSJ and the remaining connection of the UVSJ will have a , Antennas Direct PA-18 preamp.
Antennas Direct has a UVSJ , antenna combiner , in a weather protected plastic housing.
Here are some Strong and Sturdy antenna mounts, http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Buy the ronard antenna mounts at solidsignal by typing the word ronard in the sol,idsignal search box.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.winegarddirect.com ,
