Old 1-Aug-2012, 1:00 AM   #3
Tv Reception.
A simple reception situation.
Install a ANT751 antenna - Above The Roof - aimed at about 95 degree magnetic compass reading (east).
As always the starting antenna aim direction is --> the starting antenna aim direction.
The starting antenna aim direction is 95 degree magnetic compass , the antenna aim direction is then adjusted for best reception.
Buy the ronard antenna mounts at solidsignal by typing the word ronard in the solidsignl search box.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com.
As always antennas receive the best when nothing is crowding in to reduce or block reception.
Trees and tree leaves do a great job reducing and blocking reception.
Other buildings reduce and block reception.
Aiming the antenna in to the roof of your house will reduce and block reception.
Mount the antenna up high.
Mount the antenna were there is the least amount of objects in the the way of reception to the , east and north west.
