Mount a Winegard HD7096P above your roof. Aim the antenna to 237 degrees magnetic. Avoid mounting in a spot with large trees in the direction of the stations. Do not use a pre-amplifier because you have strong signals that would cause the pre- amplifier to overload comming from the same direction as the weaker stations that require the fairly large High VHF/UHF antenna.
If you are hooking up more then two sets and or have long runs of coax you can add a Channel Master CM3014 distribution amplifier.
Reason: degree correction
