A easy set-up for 7-9-16-31 with a short boom and no rotor.
Use an Antennas Direct DB2 aimed around 95 degrees magnetic for real channels16 and 31. Use an Antennacraft Y5-7-13 aimed to 147 degrees magnetic to receive real channels 7-9. Use a Winegard AP2870 amplifier. This has seperate U/V inputs and one coax output.
You could add a rotor later if you need more channels. Use an Aspen Eagel Roto 100. This will be easy as it is compatable with the 2870 amplifier in the rotor configuration that operates off of the signal coax.
