Thanks so much. Is there a better quality of coax cable I should be looking for, or are they all about the same?
Also, how do you channel scan when you have two antennas? The second scan would overwrite the 1st scan channels. At least that's what my TV does when set to Auto scan. If you try to manually add channels you can't specify the sub channels, 27-1, 27-2, ...
