Old 19-Sep-2010, 7:53 PM   #4
No static at all
No static at all's Avatar
Yes, the HBU22 would probably do the trick, but I like to go one size larger to make up for bad weather, trees, houses or anything else that may cause signal interruptions. I also like the Winegard HD series because they have a weatherproof 75 ohm ready connection.
I would guess that the maturing trees in your area are causing the signal irregularities you are experiencing, especially since it is only affecting the UHF channels.
