Old 31-Jul-2012, 7:23 AM   #7
Tv Reception.
Both tvfool radar map reports are showing the same Tv stations/channels , WHAS-TV 11 ABC and the rest.
If the HD7694P antenna were mounted above the roof aimed at about 142 degree magnetic compass , the direction of WHAS-Tv 11 , and reception will be improved for the other Tv stations/channels also.
More Tv stations/channels will be received with the antenna above the roof.
As always Tv antennas receive the best when there are little or no obstructions in the way of reception such as , trees and tree leaves , and buildings , in this reception situation the directions of south east and north east.
Here are some above the roof antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Here are places to buy antenna supplies , http://www.solidsignal.com , http://www.amazon.com , http://www.channelmasterstore.com.
A recommendation for signal distribution.
Install a Channel Master CM3414 , 4 way distribution amplifier.
The antenna is connected to the CM3414.
And connect the coax wiring so that a coax goes out to each Tv location from the 4 outputs of the CM3414 distribution amplifier.
