Old 19-Sep-2010, 7:40 PM   #12
Tower Guy
Originally Posted by goosemasterkl View Post
something that I can't figure out.
Thanks;
You have two extra strong FM stations, WSOF on 89.9 and WKMD on 90.9. The stacker antenna receives FM very well. The tunable FM trap in the AP 8700 can be adjusted to eliminate one of them, but not both. You can try to tune out the strongest one, but I suspect that you'd be better off with an HLSJ used as a low band trap. Install it between the antenna and the preamp with nothing (or a 75 ohm termination) connected to the L input.
You may also have to drop down to a HDP-269 preamp.
