I've had similar issues like this at my present location. Changing antennas solved the problem.
Probably an issue with multipath just like here. The Stacker is a good antenna and should be able to do the job there. In my case I had trouble getting all my stations with the CM 4228 and U8000 both of which are 8 bay screens. When I switched to a Yagi style MXU59 and 91XG then I was able to get every local station with a strong signal.
My guess is that those trees are the problem. You may have to try moving the antenna to another spot or perhaps put another antenna in front of the tree to get the stations you want. I tried that here with a CM 4221HD and that too worked well.
