Old 17-Jan-2010, 5:18 PM   #2
mtownsend
Hello and welcome!
Originally Posted by pcpro215 View Post
Could someone please help me figure out which antenna I should get?
It looks like you're in between Milwaukee and Green Bay market. You have more channels available from Milwaukee, so I suggest that you just concentrate on getting those stations.
It is recommended that you go with at least an attic antenna. Rooftop would be even better (maybe mounted on a chimney or using an eave mount).
The best antenna for the job is something like the Winegard HD7695P (on the roof). It is good at handling channels 7 through 69 (no support for channels 2-6), which is all you need for your situation.
If you prefer an in-attic installation, you will lose a bit of signal, and you probably want to go up one size in antenna to an HD7696P to make up for the difference.
Pointing the antenna at a compass heading of 196 degrees will give you optimum coverage for all the Milwaukee stations.
If you plan on splitting the signal to multiple TVs or have very long cable runs to deal with (over 50 feet), then you might want to consider adding a pre-amp. Chances are that you won't need one since your signal strengths are pretty good, but just keep it in mind in case you notice any degradation in signal integrity.
