If your deck has a view from NW to North use a Terk HDTVo (un-amplified). If no NW view is possible, use a Terk HDTVi located at a North facing window.
With the HDTVi you will need to lower the VHF rods to be parallel with the floor and set the length to around 24 " end to end. Aim the antenna North.
