Old 30-Jul-2012, 5:10 PM   #3
Tv Reception.
This Tv transmission is far to weak and will not be received.
KLXV Real channel 11 , PBS.
This Tv transmission is far to weak and will most likely will not be received.
KTNV-DT Real channel 13 , ABC
These Tv transmissions listed below are Very Weak , The best antenna for reception is the Winegard HD5030 VHF antenna.
Aimed at about 275 degree magnetic compass. Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html.
K06PG-D Real channel 6 , PBS.
KSNV-DT Real channel 2 , NBC and Untamed Sports and Antenna Tv.
KLAS-DT Real channel 7 , CBS.
Connect the HD5030 antenna and the UHF 4 bay antenna together with a UVSJ = UHF/VHF Separator/Joiner.
Type UVSJ in the solidsignal search box.
The HD5030 is connected to the VHF connection and the UHF antenna is connected UHF connection of the UVSJ.
Connect a Antennas Direct CPA-19 preamp to the remaining connection of the UVSJ.
The output of the CPA-19 goes to the Tv/s.
For one Tv connected use no splitter.
For 2 Tv,s connected use a , http://www.hollandelectronics.com , also available at http://www.solidsignal.com.
HFS-2D , 2 way splitter.
For 3 Tv's connected use a
HFS-3D , 3 way splitter.
For 4 Tv's connected use a
HFS-4D , 4 way splitter.
Thse splitters are power passing splitters so the preamp will get power through the splitter.
Please make a second tvfool radar post at 60 feet antenna height to see if the signal strengths improve.
The Tv transmissions are very weak. The only way to find out if reception is reliable is to do the install and see.
As always the starting aim direction of a antenna is -> the starting aim direction of a antenna.
The HD5030 can be turned to find a aim direction with the best reception.
For your reception situation about 240 to about 320 degree magnetic compass or so.
Here are some places to buy antennas and ect. , http://www.solidsignal.com , http://www.amazon.com , http://www.winegarddirect.com , http://www.antennasdirect.com
