Old 19-Sep-2010, 2:36 PM   #7
Billiam
Originally Posted by goosemasterkl View Post
I tried un-hooking the preamp and now I can't pick-up anything. Let me know what you think the problem is. Thanks
Did you remove the cable from the preamp at the mast and also at the tv? If you keep one end of it plugged into the part with the AC outlet, it won't work properly either with or without the preamp. You have to completely bypass all the preamp components.
