Thread: OTA reception
Old 30-Jul-2012, 3:07 AM   #1
SarahRay
OTA reception
Just got an OTA antenna that is inside our condo. It is near both an east and south facing window. We are on 3rd floor of brick building- approximately 30 feet off the ground. We are having trouble with WTMJ, 28 (4.1). It comes in strong for a minute or two, then after that it has weak signal and cuts out periodically. Commercials seem to come in just fine without any freezing or cutting out. We have tried moving the antenna around with no luck. Other stations have worked better with very little freezing or cutting out. The link below is our signal analysis report. Looks like it's only 3 miles away, similar to WITI, which we have very little problems with.
http://www.tvfool.com/?option=com_wr...99009e6c1c4488
SarahRay is offline   Reply With Quote
