Old 17-Sep-2010, 8:21 PM   #13
fonzie888
What do you recommend?
Should I mount the C4 (if I have to potentially combine C5) on a 5 foot mast?
What are the proper grounding procedures? I have been told to add a grounding rod and run ground wire from raw spot on mast to rod. Then I am to connect rod wire to grounding block with coax fitting on house prior to running second RG6 coax into the home. . Does this sound correct?
Input on both would be great!
Also, do you think my c4 will need the Pre AMP whether or not I add the C5?
My wire run will be 75-100ft.
Here's my profile:
http://www.tvfool.com/?option=com_wr...a36240fd2c3537
fonzie888 is offline   Reply With Quote
