At 20 miles with high-VHFs @30 kW with LOS, the UHF antennas such as the C4, DB4, or DB8 will do fine.
How about this: You get one of the named antennas (I'd suggest either the C4 or the DB8 as they will do better on 12 & 13) and, if it doesn't get the two VHF channels on 12 and 13 (the one on 10 is a home shopping channel...), I will personally send you a C5 at no cost to you.
You cannot loose with this offer.
