Old 28-Jul-2012, 7:28 PM   #3
Tv Reception.
WUFT-DT Real channel 36 , Virtual channel (5.1) PBS.
WCJB-DT Real channel 16 , Virtual channel (20.1) ABC and The CW.
WGFL-DT Real channel 28 , Virtual channel (28.1) CBS and MyNetwork.
WOGX-DT Real channel 31 , Virtual channel (51.1) FOX.
WRUF-LD Real channel 5 , Virtual channel (10.1) IND.
WNFT-LD Real channel 15 , Virtual channel ( ? ) , IND.
WNBW-DT REAL channel 9 , Virtual channel (9.1) NBC and Me-Tv.
http://en.wikipedia.org/wiki/WNBW-DT.
http://www.rabbitears.info/market.ph...callsign=83965
W40CQ-D Real channel 40 , Virtual channel ( ? ) Religion.
W23DG-D Real channel 23 , Virtual channel ( ? ) IND.
The Tv transmissions are Very Strong at your location , a amplified antenna , will over load from the strong Tv transmissions and be the cause of bad reception or no reception.
I recommend use a plain and simple , non amplified rabbit ears and loop antenna. Radio shack has Plain and Simple NON amplified rabbit ears a indoor type antenna.
http://www.radioshack.com , #15-1874 .
Aim the plain and simple non amplified rabbit ears type at about 273 degree magnetic compass -West.
Here is how to aim indoor type antennas , http://www.kyes.com/antenna/pointing/pointing.html.
Another direction to aim the plain and simple rabbit ears type antenna is about 325 degree magnetic compass.
The Tv Must Channel Scan for the Digital Broadcast Tv Channels sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
DO NOT channel scan for the cable tv channels.
Put the plain and simple non amplified rabbit ears type antenna in a window that faces West.
A better indoor type antenna is the TREK HDTVi , Non amplified antenna.
http://www.solidsignal.com , http://www.amazon.com.
For a above the roof antenna install a HD7000R antenna aimed at about 325 degree magnetic compass or 273 degree magnetic compass.
Here are some above the roof antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
