Tv Reception.
The second antenna system is the DB4e with preamp aimed at about 290 degree magnetic compass.
This is a separate antenna and coax system that is not connected to the other antenna system.
When both antenna systems are used then the A/B switches are used.
If one antenna system then no A/B switch.
Here are the Tv stations/channels for the DB4e system.
Retro Tv Network , Tuff Tv a Tv channel for Tuff Men , Family Tv Network , FOX , MTN The Mountain Tv Network.
Also this antenna needs to be up high to clear the trees and tree leaves.
