Old 28-Jul-2012, 3:17 AM   #5
Tv Reception.
For reception of the Tv stations/channels with out a rotor.
Many , many , many , Tv stations/channels will be received.
Install a Antennas Direct DB4e with a Antennas Direct CPA-19 preamp aimed at about 290 degree magnetic compass.
And install a Winegard HD7696P antenna with a Winegard AP8700 preamp aimed at about 165 degree magnetic compass.
These are 2 Separate antenna systems that wiil not be connected togeather on to one coax.
The 2 separate systems and coaxes will go to the location of the Tv and be connected to a remote control A/B antenna switch , http://www.radioshack.com , #15-1968 , or , http://www.mcmelectronics.com , #32-4425.
If you like you can start with one antenna the HD7696P and preamp aimed at about 165 degree magnetic compass .
For the reception of , NBC , The Live Well Network , ABC , CBS , PBS , FOX , Me-Tv , The CW , Antenna Tv , MyNetwork.
The antenna needs to be mounted up high , I advise clearing the trees (antenna above the trees) for the best reception.
Here are some antenna mounts , http://www.ronard.com/Tripods%200703/4712.html , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html. http://www.ronard.com.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.antennasdirect.com , http://www.winegarddirect.com , http://www.amazon.com.
For one Tv connected use no splitter.
For 2 Tv's connected use a .
HFS-2D , 2 way splitter.
http://www.hollandelectronics.com and also at http://www.solidsignal.com.
