Old 28-Jul-2012, 3:00 AM   #14
WildmanCAL
Thanks for the information, ADTech. Much appreciated.
On another note, I have decided I need to upgrade my antenna as I am having problems pulling in signals from a few stations I'd like to get. Currently, I have my antenna pointed at 314° and I can get most of the stations I need. However, the two stations which are located at 358° (36 & 50) are having a lot of dropout.
Would the Winegard HD7694P cover the range I need (from 300° to 358°) and pull in the channels I want or should I consider something like the AntennasDirect DB4e (with the VHF dipole from my current DB4) be better for what I need. Also, would I be better off using my current DB4 pointed at 358° and then install the above-mentioned Winegard combining the signals with a UVSJ?
Thanks, again, for all your help.
WildmanCAL is offline   Reply With Quote
