Old 27-Jul-2012, 8:09 PM   #5
Tv Reception.
A one antenna solution.
If you have been reading for several months then you know that Hoa's can not delay or prevent you from installing antennas above the roof. And you can install any size antenna to get reliable reception.
And you can install the at the location that gets you reliable reception. The Hoa can not make you hide the antenna.
And you know that this Federal Antenna Law is in effect for 16 years. http://www.fcc.gov/mb/facts/otard.html.
Hoa's are well aware of the Federal Antenna Law and they know that they must comply with it.
If you will like to receive ALL The Channels that you have requested.
Then install a Antennas Direct Clear Stream 2 Complete UHF/VHF antenna above the roof in such a manner that the Clear Stream 2 Complete UHF/VHF antenna has a good shot at the Tv stations/channels to the , north west , south , south east. http://www.antennasdirect.com/store/...VHF-Combo.html
Remove the Reflector Screen from the Clear Stream 2 Complete UHF/VHF antenna , and aim either side of the Clear Stream 2 Complete UHF/VHF antenna at about 145 degree magnetic compass.
With the reflector screen removed the Clear Stream 2 Complete UHF/VHF antenna will receive the Tv stations/channels to the , north west , south , south east.
http://www.antennasdirect.com/store/...VHF-Combo.html.
Install a Channel Master CM3414 , 4 way distribution amplifier.
The Clear Stream 2 Complete UHF/VHF antenna is connected to the CM3414 distribution amplifier and the 4 outputs of the CM3414 distribution amplifier go out to the 4 TV's.
Here are some above the roof antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.antennasdirect.com , http://www.channelmasterstore.com , http://www.amazon.com.
