Tv Reception.
The Tv's Must Channel Scan for the Digital Broadcast Tv Channels sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
If the Tv's are older Tv's that do not have a , Digital Broadcast Tv Tuner , then a converter box is required to receive the Digital channels on older Tv's.
Walmart , RCA Digital Tv converter box , model number , DTA800B1 .
