Tv Reception.
Yes the Tv stations/channels to the south west will be received by the HD7082P antenna.
Yes KTBC at , 227 true , 223 magnetic compass , will be received.
And
Yes KCWX at , 253 true , 249 magnetic compass , will be received.
All the information that you and I have both provide shows that KCWX is transmitting on Real VHF low band channel 5.
The correct antenna to use is the HD7082P antenna because it is designed to receive all 3 Tv bands , VHF low Tv band channels 2 thru 6 , VHF high Tv band channels 7 thru 13 and UHF Tv band 14 thru 51.
The HD7694P antenna is designed to receive , VHF high Tv band channels 7 thru 13 and UHF Tv band channels 14 thru 51.
You can call the Tv station , ask for the engineering department , ask what the actual channels are being transmitted.
