Old 26-Jul-2012, 3:59 AM   #6
buckeye1953
Channel 5 or Channel 8?
In this channel lineup, it lists TWO stations as KCWX. One appears to be broadcasting on channel 8 from the Austin antenna farm about 7 miles from here.
The other KCWX appears to be broadcasting on channel 5, but from San Antonio, about 57 miles from here.
Are these both the same stations? The KCWX website lists it as a San Antonio channel only.
Another question: If I get an antenna capable of picking up the station 57 miles away, would that be a bad antenna for picking up our local stations just 7 miles away?
AND - if one station I absolutely MUST be able to get is 7 miles from here at 227 degrees, but the one 57 miles from here is at 253 degrees, would these antennas be able to pick up BOTH?
Thanks for your advice.
buckeye1953 is offline   Reply With Quote
