Old 26-Jul-2012, 3:57 AM   #6
Tv Reception.
The one meter in size applies to the small satellite dishes.
Tv antennas can be any size to get reception.
It is important understand concept and then the actual fact and get the wording correct.
Some Hoa's and housing coven-nuts and etc. are not very friendly and will use any slip up you make.
That said the Tv transmissions are so strong at your location that if the roof is not a metal roof , you can put the antenna in the attic or above the roof and the reception will be the same.
Here is the Federal Antenna Law that says yes you can , install , use , maintain , a Tv antenna of any size above the roof to get reliable reception.
Read this Federal Antenna Law and understand that it is written in your favor and provides for you concrete legal rights to , install , use , maintain , antennas and stops the antenna haters dead in there tracks.
http://www.fcc.gov/mb/facts/otard.html.
Make no mistake , there are people that despise and hate antennas , they hide behind rules and regulations and say bad things about antennas.
Think about this , antennas are made of metal and plastic , does a normal person despise and hate metal and plastic.
