Old 16-Sep-2010, 2:30 PM   #7
Dave Loudin
Or, if there's enough slack, disconnect the coax from the output of the preamp and connect it directly to the antenna. What's happening is the two closest stations (WAZE and WKMA) are overloading the preamp, causing lots of distortion and extra noise over many channels that is wiping out most of your reception.
To properly assess what is possible without the preamp, rerun your report for the correct antenna height.
