Old 25-Jul-2012, 10:26 PM   #5
OTAtime
Originally Posted by bud-- View Post
The mast must also be connected to the earthing system. This is not protection from a direct lightning strike to an antenna or dish.
So, is this protection for humans near mast/antenna in case of a potential voltage?
What is the appropriate wire size that should be used for this (ground from mast to earth)? For example, a case where antenna is approx 30' from earth ground rod in the attic.
OTAtime is offline   Reply With Quote
