Thread: Antenna advice
Old 25-Jul-2012, 5:29 PM   #5
Tv Reception.
ALL of the Digital main channels and digital sub channels Will Be received.
The GROUP of Tv stations/channels at about 342 degree magnetic compass will be received.
KIIN channel 12 PBS and KWKB channel 25 The CW are so Strong Signal Strength that these 2 Tv stations will be received no matter what direction the antenna is aimed.
KYOU channel 15 Fox is a strong signal will be received at the back angle of the HD7696P antenna.
There is also KFXA channel 27 FOX and the Country Network that is received at the front of the HD7696P antenna.
That leaves the Tv stations/channels to the south east , they will not be received by the HD7696P.
They are more of the same , NBC , CBS , ABC and etc..
They are Distant Tv signals to the south east (at about 111 degree magnetic compass) and will require a rotor with a larger antenna , the rotor is so you can watch your locals and rotate around to watch the distant stations.
Antenna rotators are not channel surfing friendly , must wait for antenna to rotate and not every one will agree with where the antenna is aimed.
The other way to receive the Distant south east Tv stations is install a second antenna a Winegard HD7082P / HD7084P antenna with a AP8700 preamp aimed at about 111 degree magnetic compass.
The 2 antenna systems Will Not be connected together on to one coax , it will be Separate coax systems all the way to the Tv's where remote control A/B antenna switches at each Tv location will be used to to switch from one antenna or the other. http://www.radioshack.com , #15-1968 , or , http://www.mcmelectronic.com , #32-4425 .
The remote control A/B switch set up is channel surfing friendly , push the button on the remote control , change antennas and keep on channel surfing.
I recommend the one antenna to start with , the HD7696P antenna set up. ALL of the Digital main channels and digital sub channels will be received.
______________________________________________________
The Pomeranian that lives with me likes to swim in the lake.
