Old 25-Jul-2012, 5:16 PM   #4
The SD-3700 is functionally equivalent to a 2-way splitter. It has no filtering that would reduce undesired signal from one antenna or favor desired signal from the other. If you receive a usable signal on one antenna, mixing a weaker signal from the other antenna is just as likely to subtract from or interfere with the strong signal as add to it... without filters for each channel it's a roll of the dice. If you want to get an idea of costs for effective filters, contact tinlee.com.
On the other hand, it's fairly cheap. A few people manage to get lucky combining broadband antennas with a broadband combiner (a reversed splitter). Most people are disappointed with the results though.
http://forum.tvfool.com/showthread.php?t=2882
http://forum.tvfool.com/showthread.php?t=820
http://forum.tvfool.com/showthread.php?t=8275
