Install a Winegard HD7082 all channel antenna and a Winegard AP8700 amplifier.
To receive all networks you need to install a rotor. The Aspen Eagel Roto 100. This combo will run thru the exisiting coax, provided the distance is less than 75 feet and you remove all satellite splitters. If you need to split the signal use a splitter that passes DC on one port. Run a coax from that DC pass port to the rotor controller.
