Old 16-Sep-2010, 11:31 AM   #11
Dave Loudin
You would be buying the antenna for all the stations in the yellow/red. Look at the real channel column. Those are the actual channels stations are broadcasting on. Between your locals and the Pgh. stations, only two broadcast on VHF. You can buy a UHF-only antenna and not worry about those, or you can buy a VHF/UHF antenna and get those - your choice. By aiming at Pgh., you probably will not get WPCP and you will definitely not get WTOV. The only solution would be to buy a rotator, and I don't think you want to do that for only two channels.
To help you sight the antenna's aim, go back to the maps page and turn on the lines option. Zoom in on your house and you will see landmarks you can use to aim on.
