Tv Reception.
Yes the typical , J shaped satellite mount or other satellite mounts can be used to mount the CS2 Complete UHF/VHF antenna.
If a mount is not at the top of the roof then the mount Must Be Moved so the mount and CS2v Complete UHF/VHF antenna is UP High so the CS2v Complete UHF/VHF antenna has the best unobstructed shot at receiving the Tv stations/channels to the north/north east.
Also the CS2v Complete UHF/VHF antenna needs to be mounted so the antenna is straight up and down , do not have the antenna tipped at odd angles.
I Strongly Say Do Not mount the CS2v Complete UHF/VHF antenna inside the attic or inside the house.
Some of the Tv transmissions at your location are weak , the CS2 Complete UHF/VHF antenna needs to be out in the open to get all the signal it can.
____________________________________________________________________
Teleview
moving closer to the truth.
Reason: Clarify information and typos.
