Old 24-Jul-2012, 4:48 PM   #20
signals unlimited
As we have been suggesting, you must determine if your poor reception is a problem in your system or antenna size/gain.
If you run a new coax (out a window or door) from the antenna to the set we will know what changes are needed in your system.
If you need an antenna change go with the @teleview 7084 antenna and 8700
pre-amplifier, add a Channel Master 9215 rotor and you will add another group of channels at 130 degrees.
