Old 24-Jul-2012, 4:36 PM   #3
kyaman
Originally Posted by signals unlimited View Post
Use a Winegard HD 7082P all channel antenna, aimed to 103 degrees. If your home has a standard shingle roof, that is all you need. No rotor, no pre-amplifier. If you are hooking up more than 3 or 4 sets you could use a distribution amp.
There will be no interferrence from the FM antenna. It only receives, does not transmit.
Thank you very much. Standard shingles so that sounds good. It seems you choose the model because it still covers 35 miles on UHF and gives mevery good VHF, is that accurate?
I am Ok finding the compass direction, just was wondering if the "fat" or "thin" part of the antenna needs to point to 103 (and the other pointing at 283) or does it even matter?
Also to connect my old VHF to my tuner can I also use Rg6 cable (tried looking up but couldn't find specific answer, maybe this is too basic of a question
Thanks again.
kyaman is offline   Reply With Quote
