DTV/cell phone reception advise
Use a Winegard HD 7082P all channel antenna, aimed to 103 degrees. If your home has a standard shingle roof, that is all you need. No rotor, no pre-amplifier. If you are hooking up more than 3 or 4 sets you could use a distribution amp.
There will be no interferrence from the FM antenna. It only receives, does not transmit.
