DTV/cell phone reception advise
The hills between you and channel 4 are hindering your reception from the transmitter main lobe. The signal to the East is bouncing/reflecting off of the hill that you described. It was probably there all along, and could be a somewhat reliable replacement for the missing channel.
If you can rely on the reflected signal from the East, keep the DB8 and rotate
when needed.
