Old 16-Sep-2010, 2:23 AM   #8
tbird2340
Originally Posted by Dave Loudin View Post
Before we're finished, you need to rerun your report and vary the antenna height at the point where you can drag the receive marker on the map. Every time you click away from the box, the predictions update. What you're looking for is a big increase in the NMs of the Pittsburgh and Akron/Cleveland stations.
Based on your current data, I'd recommend a Winegard HD7698P aimed at Pittsburgh. If you don't care about WPCW (CW) and WQED (PBS), you can use an Antennas Direct XG-91 aimed at Pittsburgh. Either way, the locals are strong enough to come in off-axis.
IF, and ONLY if the NMs improve to at least near zero for the Akron/Cleveland stations, I would use a rotator with the Winegard antenna.
Good luck!
Ok, so here is a more exact reading. I zoomed in all the way and clicked right on my chimney.. I then put the antenna height at 25'.. I have a two story house so I'm assuming that is about the height the antenna will be it..
I don't think the Cleveland/Akron stations are going to be possible. Also, why did you say if I don't care about WPCW (CW)? Isn't that really close to KDKA which is the channel I'm most interested in?
Can you tell me why you suggest uni-directional antennas instead of the two that I was initially thinking about? I don't doubt your knowledge, I'm just trying to get a better understanding..
Thanks again for the help! Those tvfool tools are amazing! Would be even better if you could select the antenna you want and see the results!
tbird2340 is offline   Reply With Quote
